Could be in need of a carb cleaning or rebuild followed by synching the carbs.
The first thing I would try is a full can of Seafoam in the gas tank to see if that helps clean out the gunk from sitting.
You should also check to be sure no water or even worse rust has gotten into the fuel tank from the long lay up.
GoldWings like to be run. When they sit for long periods they begin to self destruct.
