1 - 20 of 20 Posts
96 gl1500
I just bought a Bad Boy Air horn. Will it just hook up to exsisting connection when I remove the stock horn? Anyone ever installed on a 1500?
Wingrider59:praying:
2000 GL1500SE
Does the Bad Boy have a relay built into the wiring? If not you will need to add one to the circuit. Otherwise it will be too much current for your horn button and will burn it out shortly.
I removed the left side pocket and side marker and hide mide in the hole using the original wire as a sigal to trigger the relay YOU ABSOLUTLY NEED A RELAY to trigger the bad boy's the air pump draws lots of Amp for a great job.....
mr irrelevant
yes you need a relay, and if you go to harbor freights website you can get the manual that comes with it..the two wires from the bikes wiring plug onto two of the relay posts ,then one goes to positive of horn, other goes to positive of battery on the bike...
Ignoramus Primus
A relay AND a fuse. Please do it right.
I left my stock horns in place and tapped into the horn wire to trigger the relay for the BadBoy horn.
EZ and effective mounting is to zip tie the horn to the radiator grille up front.
The BadBoy is definitely LOUD and will make soccer-mom drop her cell phone.
mr irrelevant
You are correct it does need an inline fuse also..good catch n sorry I forgot to add that! !
You can use the bikes wiring, no need for new wires. Just run them through the relay and on to the Bad Boy. The fuse for the existing horns usually works fine, but it won't do no harm to add a separate fuse.
On mine I use the original wiring for a signal only leaving the amprage job to the relay not to the switch and I ran a good size wire and fuse since this sucker draw power for a good efficiency enjoy...:waving:
:shock: That was simpler than sticking it in the fairing? I did mine in the right front fairing. VERY simple.
It was for me, as that space (and the others large enough to hold the horn) had already been filled with previously installed accessories, and I was too lazy to move them again...;)
The above will lead you to replacing the horn switch in short order... The Bad Boy comes with wiring instructions... Follow em... You will need a 12ga fused feed from the battery to the relay run the horn... The old horn wire is used only as a trigger to the relay...
Monkey with a Football
Right on, Ed!
Nevermind.
1 - 20 of 20 Posts
