Hi,
I've had my gl1800 hundred about 19 weeks now and have covered just under 9500 miles, I experience slight handlebar vibration which i think couldbe cured with slightly heavier bar ends.
Does any one know of a source for heavier bar ends?
Many thanks for you help.
I have changed my bar weights for the ones that come with the iso grips and it does not make any difference - the ride and feel is the same. A vibration at the front is possibly a tyre problem or fork problem. Is the vibration at all speeds or just ina small range :shock:
The vibration is only in the range of 3 - 3.5 k revs the most used.
Its an annoyance rather than a problem and has been present across both tyres, second has only 1200 miles on it
Don't know about 1800 bars, but I've always put a patch of "Innertube" under my bars and that solved it! Cheap too!
What an excellent idea - the patch.
On the vibrations, if this is your second set of tyres and it is still happening, I would think about having them re balanced and check the head bearings for loosness.
That speed range seems tooccur withdunlop or metzler tyres although I expect it could happen with any tyre. Just a thought, it may be the rear causing it
GERIATRIC MEMBER
tanygaer wrote:
Hi,
Hey tanygaer :waving: [shadow=green]WELCOME [/shadow] to the best Goldwing Forum on the net. :clapper: I dont think weights are your problem. The wheels probably need to be balanced and make sure that you have [shadow=red]BRIDGESTONE[/shadow] Tyres fitted. You sure make great use of your :18red:9500 (s)miles in 19 weeks. I know one guy that has his :18red:almost three years and has 1560 miles completed. :stumped:
:weightlifter::18red::weightlifter:
