Pulled the heads off my 82 GL1100 over the winter due to a coolant leak behind the exhaust. Rebuilt the carbs while I was at it. Got her all put back together this spring. Was syncing up the carbs and pulled the line off of the #1 brass vacuum tube that was screwed into that vacuum port to cut the tube down a bit and noticed a PUFF! PUFF! PUFF... Thought to myself, hmmm, I know there should be a vacuum pulse there, but I'm pretty sure there should NOT be any pressure pulse blowing out! ACK! Pulled the valve cover off, rocker arm assembly, took springs off the intake valve and shined a light down in mouth of the intake port to inspect the valve as I spun it.. Sure enough, freakin bent valve incapable of seating
Racking my head trying to figure out how I did that. Stupid!! I'll be more careful with reassembly this time.
