My 1988 gl 1500A ( with 15,800 miles) runs pretty well when in nuetral but dies when placed in gear. The clutch is not stuck up. The kill switch, 2 clutch switches, the reverse switch, side stand switch, nuetral switch, 7 diodes (5 at the rear, 2 on right front side), the Bank angle sensor, the reverse relay switch, power relay switch, fuses, and relays on the left side relay box, two other relays at the left rear side and the relay on the left side of relay B, all tested good.
When ignition switch is placed on " ON" position, nuetral light, reverse light, oil light, cruise indicator light, all lights up momentarily. Nuetral light remains lighted. Fuel level indicator light does not come on.
When in reverse, the reverse light does not
come on. Reverse operates only around 2 seconds.
I haven't tested the gear indicator switch because space is too tight. I tested the reverse power unit too. Body ground is clean. Can't find anything wrong.
I have continuity on white/green wire (from the reverse control unit) with green wire. The green/red wire has power all the time. Can somebody tell me what I am missing.
