This is the third time this has occurred. After I open it up a bit, once I come to a stop, it wants (and does) stall. It will do this for a while until it's better at some later point, but it never runs as good as when I first start and ride it. I know for certain that the carbs need to be re-built, but would that cause such a condition or is it electrical in nature? My gauge shows 13V most of the time, but after the above riding does dip down to 11 sometimes. I usually run with the hi-beam light on since the low is very dim. Switching to low beam, naturally, does improve the situation and the volts return to 12V or so.
