1 - 11 of 11 Posts
Hello All,
Just joined the forum and am looking for a second opinion on what I have for choices concerning a pending goldwing purchase.
I know there are going to be a lot of different thought processes on this issue but I welcome the feed back either way.
It has been a dream of mine to own a goldwing for some time, and that time seems to be now.
I have a budget and have been debating about two different bikes.
One is a 1993 SE with 45K miles. The bike is in good condition the only thing wrong is the cruise control does not work. Second owner/previous owner his father.
The other is a 1997 SE with 90K miles. This bike is also in good condition but has blown speakers. Second owner/Previous owner ?
I am very mechanical and would have no problem doing anything to the bikes my delema falls with do I go for a newer bike with double the miles or a older bike with less miles? What are all your thoughts?
Thanks for the help.
Morning
The biggest problem with cruise on a 1500, in my experience has been the micro switch on the front brake lever. Drive the bike and push the brake switch forward and try the cruise. Simple fix.
Jaxn
Morning
Jaxn
I agree, common problem indeed and can manifest itself on the 1800 too.
The first bike sounds a good bet, especially if you can find that it has been ridden regularly in recent months/years.
If either has been standing a long while then go for the other one is as much as I can say, without seeing the bikes. The Tupperware is quite expensive to replace so if any of that is in poor shape that may persuade you to the other one. :?
Hard to choose since both are only just about run in, if they have been looked after well, any service history on offer?
Take my word for it......
Get 1 of each.... a 1200, 1500 and an 1800 and get it over with.
If you love the GoldWing, it's inevitable anyways.........
+1 on maintenance record---- would really be nice to know.
My personal opinion is get the newest you can afford. Another reason i would get the 97, it has the stronger Valkyrie transmission. Not all older ones before 97 has tranny problems but a lot less chance with the 97. Guy at Moonshine Run had over 345K on his 89 that he bought new and still going strong.
I'd lean towards the older bike with fewer miles and a known history...all else being equal. If the micro switch at the front brake lever is bad, that's $12 item...I just replaced mine. Best of luck with your choice.
Vintage Rider
I prefer the 1200 and older four cylinders, but I wouldn't recommend getting one unless you are a decent mechanic and actually like to do a lot of wrenching. These bikes are around 3 decades old now, and have many of the same age related problems as other older bikes, plus parts can be hard to find.
I have been considering a 1500, for the reliability. I'm afraid to go very far on my 1200, and Goldwings are meant for traveling. I don't know all the differences in the 1500s, I would make my choice based on condition. I do know that my former boss had a transmission failure on a bought new '93 SE at around 40,000 miles, but he had a heel and toe shifter on it and rode it hard. Two things I look for on any Goldwing is the heel and toe shifter, and a trailer hitch. Both indicate more than average wear IMO. Plus I would have to replace the heel and toe shifter as soon as I bought it, I hate the things.
get a red one
There is a brass bushing on the clutch handle that gets worn, and might not let the cruise contol set. I doubt if it would take too much to get the cruise contol working. If one of the 2 has a heel/toe shifter, buy the other one.
gumbyred
2007 1800 Crucible Orange
AS mentioned the 97 will have the transmission update along with a few other slight improvments made over the years of production .
My daily ride is a 94SE with 192K miles . It came with a heel/toe shift and 170k when purchased . The shifter was changed back to stock the day I bought it , and it's still going well . My project bike is a 93Aspencade which the thranny failed at around 50k .
Regular/periodic maint records and regular use would both be valuable traits .
1 - 11 of 11 Posts
