Remove the left front side panel (the one by your left ankle) when on the bike. The bleed valve is behind that panel below the alternator. It will probably have a little rubber cap over the end of the bleed tube (unless it has gotten bad/lost over time).
I use the Honda DOT 4 brake fluid but any good name brand brake fluid will work good.
