A speed bleeder is the ticket for this one. Sure helps if doing this by yourself.
The clutch slave cylinder housing and the bleed fitting is located under the lower fairing cowl on the right hand side opposite side of the oil filter.
You have to remove the lower cowling and then take the Pollution canister thingy out of the way, Couple of clamps and a bolt or two and sitting behind it is what you are after. Kit
