Blow by in GL1500
777 Views 7 Replies 4 Participants Last post by  Winger77
I pulled the air filter only to find I have oil that appears to be coming from the left carb. Would this be a sign of needing the valves adjusted?? What else can cause it?? And if it is valves,,,,,, how much of a job is it???
How much oil is in the air cleaner? Some is normal and no it has nothing to do with the valves.
It is not a pool or puddle,,, but a good splatter of oil. It is in the air filter a bit,,,, not much more then a 2 inch diameter that is wet with oil.
I think it is more then it should be,,,,,,, just don't look "normal".
I'm not really up to speed on 1500s but all the other models have a trap for oil that gets in the air cleaner from normal crankcase ventilation and it has to be emptied occasionally as part of maintenance. If it hasn't been emptied it can be overfull to the point of spilling oil back into the air cleaner.
Oh man :gunhead:,,,,,,,,,,,, why didn't I think of that???????????????????
Yes,,,,,,, there are 2 tubes that need to be drained as needed, and I forgot about them.:gunhead::gunhead::gunhead::gunhead:
I'll be checking them and getting back here,,,,,,,,,
Thank you for your quick replies.
:clapper:Man Dave you know everything :band:
oil cant just come from the engine intake to the air filters, dont worry, valves are ok. it is probably the breather system oil
The 2 drain tubes only produced about 1-2 ounce's. I've drained more then that in the past with no ill effects.
I had her running with the filter out, so I was able to pour a little Sea Foam straight into the carbs while running. Then I give it a good dose in the gas tank. So now I'm producing an excuse to make a run to Wal-Mart ,,,,,,,,, (and have to take the long way):cool:.
I'll see how she runs.
Later,,,,,,,,,,,,,,,,,,,,,:action::action::action::action::action:
