1 - 9 of 9 Posts
78 gl1000 blowing smoke out of left exaust after a muffler conversion.馃槵what did I do?
Does it quit smoking after a while? If you park it on the side stand you can expect some smoke for a while after you start it.
  • Like
Reactions: Barney T Weasel
Yeah its ben sitting on side stand for bout a week馃 . Ill take it for a ride wen I get home an see wat happens.i started it an shut it off wen the smoke didn't stop right away
1993 GL1500 Aspy 1980 GL1100 STD
Hard to say what might've been inside the mufflers you put on, oil or something... Just ride it and give whatever it is a chance to burn out.
My radiator's fan isn't engaging but my thermostat is working any ideas?
By "thermostat" do you mean the temperature switch that is for the fan? The actual thermostat has nothing to do with the fans as they are set to come on long after the thermostat is fully open.
Yes I jiggled the connectors to the fan and an it started working again so ima just roll with it till it stops completely. Im not a mechanic and I learned the hard way if it ant broke don't fix it lol
Then fix the bad connection.
  • Like
Reactions: Bike...and Dennis
Discussion Starter · #9 ·
Links to throttle replacement videos?? None I can find on YouTube
1 - 9 of 9 Posts
