1 - 12 of 12 Posts
Just drove her home after purchase sweet 1 hr ride. Now won't start /engage starter w/ push button. Was going to try to disassemble the push button assembly but can't seem to remove it after removing the 2 main allen bolts. Need a manual or something. Help Cecil Help DIW
Transmission in neutral, neutral light ON.
What happens (if anything) when you press the starter button....??
Does the starter run when you press the starter button...but.... the engine will not start.???
Do you have the Engine Shut-Off "Kill" switch in the "RUN" position....??
Any other information for us....??
does it start in neutral?
Yes when the starter switch makes
Trans neutral w/light lit in neutral, kill switch to run pushed starter button down but no crank again same result then nothing happens now when pushing starter button by nothing
connection but starts only when in neutral in
Everything proper, starter button had contact for 2 starting attempts then nothing. Still nothing
Read this post. Very similar.
Also look through these for help.
Just went tried again now I hear a
click on every attempt. Starter solenoid? What manual can I get? Thank you guys
Did you find relay A and B? Did both click because they should. If so hold the button and test the big cables. There should be power on both terminals (studs) on both relays. That would be all 4 studs showing 12 volts. Check back.
1993 gl1500, 1976 gl1000
Download manual here. For '94 but identical to "93.
1. Remove the right side panel (the one to access the battery).
2. Have the transmission in "neutral".
3. Turn the ignition switch ON.
4. Press the starter switch (button).
Do you hear a click at the Starter Relay A (located to the right of the battery)...??? There will be "two" large battery type cables connected to the Starter Relay A. Make sure they are clean and tight...!!
If you hear the click, the starter switch (button) is working.
5. Use "two' large screwdrivers to connect "jump" from one terminal to the other terminal on the Starter Relay A.. The starter should run and the engine should start.....!!
Note: There will be a "significant spark" when you do this jump...!! That's OK.....!!
If the starter runs and the engine starts, you have a faulty/bad starter relay A.
Come back with results......!!!!
1 - 12 of 12 Posts
