Hi there! Maybe I already mentioned sometime that I have a blue smoke on startup from both the exhaustswhich disappears after a few miles (or minutes) of riding. However, the situation had changed. Today when I started the bike, like usual a large amount of blue smoke was pouring out the exhausts. I let it idle for about 20 minutes but I still had the smoke. I went for a ride and after few miles the smoke disappeared, but only temporary. When Ilet the bike idle againon its side stand there was no smoke for a first few minutes, but then I opened the throttle a little bit so the RPM increased to about 3000. After few seconds of this "fast" idling the bluish smoke suddenly appeared again, first from the right hand exhaust, then from the other one as well. The magnitude of smoke was variable, in one moment there was a lot of smoke, then less (or nothing), then again a lot, while the engine was "fast" idling on about 3000 RPM. Similar situation on both the exausts. I removed the crankcase breather hose before riding, with the engine still cold and was checking for any smoke from there since the beginning. While the engine was cold (a lot of blue smoke from the exhausts) there was abslolutely no smoke from the breather, only the air. When it warmed up (after riding), when point a bright flashlight in the breather, there wassome barely visible vapour, I think white coloured, but there was just a little bit of it, almost nothing. Normal oil vapours? Also checked up the oil filler hole, no smoke from there. Now here is the compression (measured with the engine stone cold) : #1=148 #2=152 #3=143 #4=145 Lbf psi
So, no cylinder was under 142 (the manual service limit)and the biggest difference was 9 (service limit 15 by the manual). I also noticed that the spark plugs #2 and #3 looked better than the others. They were brown coloured on top while 1 and 4 were black. So, that's it. I hope that the piston rings arenot the causeas the compression is satisfactorily and there is no smoke from the breather, but am I maybe wrong? So, I amthinking about two possible options: 1) bad valve stem seals and/or guides or 2) too thin oil (caused by the fuel coming in it as the carb floats are bad, I must fix that as well) which can easily pass the valve seals and come into cylinders. So, I must rebuild the carbs and change the oilanyway, but is it a good idea to change the valve stem seals as well?If so, then to do it without removing the heads orto remove the heads and then check the valves as well? Any other possibility, like bad piston rings or something else?
Sorry about that long text and thanks a lot! Alex
