Copy this pic, and Enlarge it. It is compressed. The original size was too big.
Jluvs2dive
Happy ThanksGiving to you and Yours also.You too.
I was checkiing the manual, and from the control unit there is a Black/brown wire (looks 2nd from rear)0 and a fuse (L shaped connectors Black under the false gas tank about 1 inch wide, 1/2 inch long, 1/4inch depth) that controls your Fuel and Heat Sensors on your insturment cluster. The Bronze 7 volt regulator also runs from this same black/brown wire. If you have an ohm meter, ground the Negative to the frame, and check the Black/brown connection on the control unit (Mabe Voltge Regular) on the front side (Rowards the Light.) If there is no power to it, it is the fuse. It is difficult to find, but it is in the MAIN Wiring harness usually can get to it with 2 fingers behind the frame bar. If you are getting power from the control box, then it looks like you will need to replace the 7 volt regulator. I hve all you need, even the blinkers like I got. We are not that far way from each other. I live in Gadsden, and I would love to help you fix this, and install a separate set of blinkers like mine, and run your Bates Lights as all Running and all Brake Lights, and have the blinkers separate. I am good at tracing.repairing these, and If you can come Down this weekend, we can work on it in my shop.
You need to bring nothing, because I have everything, and we can fix it probably fairly easy, but the rear brake system will taeke around a day to break down, repair, and put the Blinker System on. All we will need is 2 Single wire Blinker lights.
I should also be able to fix your speedometer, and Temp/Fuel Guage/sensors. These are on page 8/4-8/5 in the manual, but on the fuel sensor/brakes will take 1 day, and the instrumrents we may be able to work into the night and repair. If I could afford to stay overnite in a motel, I'd come up there, but I have to live on disibility, and I cannot afford it, but I am good at what I do. (Except TYPING LOL) I built mine up from the Ground up. Ask AZ what it looks like, and GLester about the rear light system on mine. The only thing I could not do was to sync my carbs, but I learned that in Calhoun. I am also going to post this on the tech site under your post along with the simple wiring diagram.
Thanks,
David Aka Nightrider1
(Edited for typos)
