I have noticed brake fluid on myfront right hand rotor i was wondering how likely it is that my front brakes will just give out one day. im assuming it is a leak in the caliper even though it dont change the fluid level in the master cylender. any thoughts would be helpfull
Hi Mo84, if you have fluid on the rotor, then you have little or no stopping power from that one. The pads will absorb the fluid and should be replaced when you fix the leak. If it is truly brake fluid, be careful what else it gets on, because it will remove paint and destroy plastic. Take a look at the fork tube on that side, the fluid may be oil from the fork through a bad seal.
Your rotor is just giving you a wake up call. Time to evaluate. In my experience, mechanical items do not heal by themselves and lots of times a neglected mechanical item will extract a heavy toll if you do pay enough attention to them. You are ahead of the game with a good heads up, now show the girl you care. Pamper her a little. Spend a little time cleaning. If she continues to bleed, you might as well throw some money at her. If your brakes are broke when you need them it may end your relationship with your bike. No one wants to see that happen.
Are you sure it is brake fluid?
the fork tube dose have oil on it on that side. but i didnt think it would be that because they are kinda away from each other. but like i said the master dont seem to go down any so it might just bethe fork putting oil on there im going to have to take the bike apart and see what it actualy is. thanks alot
