1 - 18 of 18 Posts
Owner's manual for 1500 states dot4 so no you can't use dot3.
Sent from my moto g(9) plus using Tapatalk
1998 GL1500 Asp and 2017 GL1800 4AC
I dont understand why honda put dot 4 in goldwings,its not like a wing is going zipping around a racetrack like a cbr does.btw,you can use dot 3 if you choose to.
Sent from my SM-G973U1 using Tapatalk
DOT3 is just fine. The only difference is DOT4 has a higher boiling point so if you ride your brakes going down a long mountain pass or racing as mentioned they might fade. I hardly see any plain DOT3 anymore, it's usually DOT3&4.
  • Like
Reactions: SIDECAR RICH
1987 GL1200 Interstate
I just use Valvoline synthetic, Dot 3&4.
It will still ruin your paint, so it must be good. :eek:
Is Dot3 ok to use instead of Dot4 in my 1988 Goldwing?
For a comprehensive answer on compatibilities of DOT 3 and DOT 4, do a search of:
DOT 3 vs. DOT 4 Brake Fluid Differences (Can You Mix Them?)
  • Like
Reactions: julimike54
Just stick with DOT4. You can find it at Wal Mart even.
  • Like
Reactions: briese
use DOT 4 LV it has a higher wet boiling point than DOT4 and provides a more consitant lever feel in a wider ambient temp range. All I use in my Valkyrie. the higher wet point also allows replacement to be extended by 1-2 yrs from what the manual calls for. I use Pentosin Super DOT 4 LV which comes in a metal can which reduces the amount of moisture it could collect will siting on the shelf.
The why is some of it labeled synthetic and some of it is not?
All DOT 3, 4 & 5.1 are synthetic. DOT 5 is silicone. Brake fluids back as-far-as I can remember, other than DOT 5, are all synthetic. I have noticed that some bottles/brands of brake fluid mention in large letters, "SYNTHETIC" as though this is something new or better. It is not. It's strictly marketing.
Seems like the ones that are "DOT" specific don't say "Synthetic"...
"Synthetics" include DOTs 3 & 4.
Now, I'm just quoting what I read on the bottles.
I don't follow what you are saying.
A note of caution is not to use synthetic or silicon based brake/clutch fluids where the manufacturer did not specify do to the internal rubber components are not compatible.
In other words don't use DOT 5 in a DOT 3 or 4 system unless you flush it completely.
I have been told that the DOT5 fluid can affect the seals in systems designed for DOT3/4 regardless of flushing.
1 - 18 of 18 Posts
