I had it happen twice on my 1200 and once on my 1500.
All three times it was the brake light switch on the rear brake pedal.
I can't speak for the 1800, but on the 12 and 1500 it is a very inexpensive part and very easy do-it-yourself replacement.
Also in all three cases, I was able to verify before buying the replacement switch by playing with the old one by hand. Follow the spring up from the brake pedal to locate the plunger that the spring pulls on. Jiggle the plunger in and out, and side to side and see if the brake light goes on/off.
On all of mine, when I pressed on the brake pedal, the light came on. When I released the light stayed on. But when I pushed the plunger the light went out. It was as if there was some corrosion inside the switch and the switch could not return home under it's own strength.
If that doesn't happen for you, and therefore doesn't answer your question, you should be able to unplug the rear switch and see what happens. On the 1200 and 1500 the switch wiring was only about 12" inches long and easily followed to where it plugged in. Hopefully for you the 1800 is the same.
I do not know this, but I would guess that the brake light switch is normally open and depressing the brake pedal closes it. If this is true, unplugging the switch should give you an open condition and the light should go out. One of the guru's should be able to confirm if this is true or not.
But if I was a betting man, I would put money on that rear brake switch being at fault.
