I just called WingStuff.com to try to get a new pad for my brake pedal and they don't have one. I believethe floor boards and pedals are made by ShowChrome. WingStuff called ShowChrome while I was on the line and ShowChrome does not make replacement rubber pads for the pedals only the floor boards.
Does anyone have a suggestion on how to get a rubber pad on to the brake pedal. My foot keeps slipping off and I don't want to be in an emergency braking situation and have my foot slip off the brake.
Thanks, Waynester
Maybe you can find an old rubber mat of some kind and cut a small peice out and glue it on with some 3M adhesive. That is what I did and it works fine.
:)ACE hardware has thick (1/2") door mates that I cut and shaped and glued in, looks like originals. Just finished them yesterday.
Goldwing Addict :-)
Some of the auto parts stores carry generic pedal pad replacements. Just measure yours and take your measurments in. You will probably find one close enough.
Kuryakyn makes one...try Cyclemax or Wingstuff etc. I have one fitted .
On my 1200 I found an old post about using an auto pad (emergency brake pedal pad actually). It works perfectly for about $2.95. It slips over the metal pad and stays in place my itseld.
HTH
JimC in NC (USA)
