1 - 2 of 2 Posts
Hello Everyone:
I would like to install the P/N 01001 SDC backoff brake modulator on my 05. Is there a way to install the backoff brakemodulator that will let me just modulate the trunk lights and not the saddle bags, or do I have to modulate all 4 lights. I would like to do this the easiest way I can. I have wiring knowledge and good test skills.
Thanks for all your help.
The best place to access the wire harness for the application you wish is under the rear trunk lower cover. Directly under the trunk in the back you can take the lower cover off and the wire harness to the trunk lights run up through conduits on each side.
Brake wire is green with red stripe.
Kit
1 - 2 of 2 Posts
