BRAKE BLEEDING SEQUENCE
1) Using the Front Brake Lever - Front Right caliper Upper bleed nipple
2) Using the Front Brake Lever - Front Left caliper Lower bleed nipple
3) Using the Rear Brake Pedal - Front Left caliper Upper bleed nipple
4) Using the Rear Brake Pedal - Front Right caliper Lower bleed nipple
5) Using the Rear Brake Pedal - Rear caliper Lower bleed nipple
6) Using the Rear Brake Pedal - Anti Dive plunger
7) Using the Rear Brake Pedal - Rear caliper Upper bleed nipple
If you feel there might still be air in the system, these further steps can be done, but are optional.
8: Pressure bleeding the lower Junction block. (Upper left side of frame sitting on bike).Follow rubber hose from Secondary master cyl to the Junction block.
9: Pressure Bleed the top Banjo bolt on the Secondary Master Cyl. (To be sure the air bubble is completely out)
Copied from Goldwing Docs
Doesn't the front brake lever only activate the right caliper?
Done as per above formula. I used a vac pump for all but the last two. I couldn't get any liquid out of the anti dive till I pressed the foot pedal. On the upper rear bleeder was difficult to work the vac pump ,wrench and vac hose so I opted to use the foot pedal.
My wife was the helper.
Man, that's a lot of nipples!:ROFL:
