probably needs new lines. they are expanding way too much and not enough pressure is going to the caliper, what year is your wing?
have you used a vacuum pump to bleed the brakes?, there is a trick, sometimes bubbles get stuck in the banjo bolts, so wrap them with rags and while pulling the lever open and close the banjo bolts, just be careful not to drip fluid on the paint.
