Hi westcoaster. Even though your brakes are linked on your 1500, the safest way remains the same.
anything 10 kph & slower, you do not use the front brake unless a collision is about to happen. Useing the front brake going slow will drop your bike quickly if your front tire is not dead strait.
Both front & rear for normal braking.
I think your linked brakes are governed by a proportioning valve to limit your front brake so a low speed brake application will not cause you to drop.
Wayne.
Wayne.
