DOES ANYONE KNOW IF THERE IS A REPLACEMENT FILTER FOR THE BREATHER BOX? DO YOU REALLY NEED ONE?
Piled Higher and Deeper
Yes and yes
there are many sources.. besides those of keithg64 above, Honda still sells the OEM.. plus others.
I'M SORRY, I WAS REFERING TO THE CRANKCASE BREATHER FILER. IT'S IN A ROUND PLASTIC BOX UNDER THE FUEL TANK. IT HAS ONE HOSE GOING TO THE CASE, ONE HOSE GOING TO THE AIR FILTER HOUSING, AND ONE HOSE GOING STRAIGHT DOWN AS IF IT IS AN OVERFLOW HOSE. THE FILTER GOES BETWEEN TWO PIECES OF WIRE MESH INSIDE THE HOUSING
It just collects fluid..water and gunk..I guess it could go on the ground?? but might blow back to rear caliper when riding, burn on muffler, cover rear rim??? any little jug could be installed to catch that stuff.
you just take it loose and dump the condesate out of it
Yes, There is. I purchased one off flea bay for $6.00, new. You can do a lot of engine damage if you do not use a breather too.
Nightrider1
Nightrider1
