I'm in the process of trying tobring a gl 1100 that has been sitting for over 5 years back to life after being in a garage fire. The bike never burned but it did get quite hot. Any suggestions of things to look for before I attempt to fire it? The engine is my main concern as it only has 16,000 miles on it and I would like to use it to replace my mega mile motor. Any suggestions would be appreciated.
Banned
I would guess, from the looks of it, that the internals may be fine.
I would change-over everything you can change-over externally...
...fan switch because of the plastic, valve covers because of the grommets, etc...
...check the stator wire for burn...
I'd pull the motor and bench-run it first when it's all changed over.
I think you'll make out fine when done.
Give it good oil/coolant flushafter it's inyour bike and before you ride...
:byebye:
Man, that bike looks like it was parked in Death Valley in August!:cooldevil:I agree, if the engine doesn't look cooked it should be useable. I'd sure check the oil to make sure it isn't baked in the case, if that should happen it might be difficult to clean out without splitting the case. I doubt it though since the seat and rear end don't look like they where terribly hot.
I've picked up a couple of low mileage garage fire bikes. On the one I thought would be the easiest to fix I had to replace most of the electronics. The other one was a piece of cake. The good news is that Honda designed that engine to get hot so they seem to handle it well.
Steve
The high ambient heat can burn insulation from wire, destroy battery, mess with any and all parts of the ignition using solid state materials. It would definitely be to your advantage to strip the melted destroyed part off, maybe make her a naked wing and verify everything...ABS melted so the heat was near, maybe too close.
Any rubber like belts, hoses, tire, valves
Electric wires, shorts, opens, bad connections
Electric connectors, melted, open
Electric devices, made inoperable, shorted
Seals, tubes
In general you should go over every thing including the frame, rims, be meticulous and log everything
Banned
john_51 wrote:
...I would like to use it to replace my mega mile motor.
Ithink he just wants the engine.
