Well, Ive got plenty of time, so I think I am going to build a couple of timing belt tensioners. One of mine shows evidence of losing it's lubricant, and there is a lot of belt residue on bothof them. Could this mean that the belts have been too tight for awhile? When Iroll them they seem to be alright, there is no roughness or binding. There is a slight bit of noise when they get to the end of their spin. Its about$135 for new ones, as compared to about $50 to build. Think I will give it a shot.
Dave:weightlifter:
I haven't seen mine in a while so I may be way off on this but... It seems like if you can get the rollers off the mounting bracket and could find a sealed bearing with the same diameter and width and attach a shaft/bolt to the bracket that the bearing could ride on, you'd have a tensioner...or am I missing something
Thats what I am going to do using the procedure here:
http://www.sdb-e.com/TENSIONER/TENSIONER-REBUILD-JCS.pdf
Piled Higher and Deeper
Both links are essentially to the same stuff (one direct and the other through the FAQ section of this forum).... Keep us informed.. and I am always interested in your specific choices and why.. there are lots of ways to skin this cat... and ask questions too.. there is a lot of trial and error information that I have not had the time to upload yet... Good Luck..Jim
