I am in the process of building a trailer from scratch. I have the frame welded up (1.25 inch square tubing) 32" x 48". I am trying to decide if I should use a leaf spring or solid mount the axle to the bed. Pros and cons would be appreciated. I will be using 12" tires. If there is anything else you need to help decide let me know. The carrier will be a Sears X-Cargo cartop carrier (18 cu. ft.).Thanks for your help. Randy
