While out riding today I was noticing that the 1500 has a kind of gear indicator. Top gear (if your OD light is out) is the only gear that the speedometer needle will be higher on it's scale than the tach. In 4th the two needles are almost parallel to each other. If the tach is higher on it'sscale than the speedo you are in 3rd or lower. Useless info perhaps but works for me until I get around to replacing that OD bulb.
