I have a 2018 GL 1800,,, when I ride it aggressively I get a Burning rubber smell coming from the bike. When I pull up to a Stop people around me can smell it..I pulled the front and back wheels off to look for rubbing signs,,,,nothing everything looks good,,,looked at the exhaust system nothing is on the pipes,,nothing.....has anyone had this problem???
2003 GL1800A
What do you mean "ride it aggressively", and does the temp needle go any higher than normal when you do?
There seems to be a common issue with a small oil leak on the left side dripping on the exhaust. Take it to the dealer, it should be under warranty.
