I was about to pull the right head off of my 83 aspy, and I got the Valve Covers off, and I found all the bolts were loose holding the camshaft. The cylinder bolts were properly torqed. My question is, with the cam bolts being loose on both heads, would this cause the coolant to get into my oil? On the right side, I could turn them with a standard 12mm wrench 1/2 turn. On the right fuel pump side, I was able to turn them 1 turn easily. Redicilous! These torque at 15ft lbs. Any help before I pull the heads would be appreciated. I am also going to check the belt timing marks and see if they are correct and torqued properly before removing the top ends.The coolant leaked down even without the engine running.
Thanks,
Nightrider1 Aka David
Thanks,
