Hey Nvrpc,
I also might add that I thought about doing something with the handlebars but decided against it. The video quality would not be what I wanted as it would be looking through the windshield. I think the glare and reflection would be horrible. Also, the camera would move with the handlebars and not stay level as you move them as you drive.
As far as safety goes... both hands on the bars!!! You should not be playing with anything that you have to look at for long periods of time to "adjust".
The GoPros do not have a screen (natively - it's an option). Pick a place to mount it and then try the camera out, view the video, adjust to taste! I did it in two tries.
I am so happy with where I mounted them on the 1100, the video was so good, that that is where I will mount them on the 1500. I will build another regulated and filtered power supply and have the camera powered off the bikes electrical system and just replace the 32mb cards as I need to (I use two and swap them back and forth).
One final note, the lower the camera is to the ground, the less you get to see and it looks like your racing like a bat out of he** while you're doing 20kph! A trick of the camera. Great if you're a race car but not good if you want to record a wonderful outing to show friends and family.
Tim.
P.S. This picture is a still (cropped a little for another project) from the GoPro mounted on the right hand side.
