I just had the engine out, but it was for the stator. It's all back in and running fine, I just plain forgot about this minor leak.
Do I have to take the whole clutch cover off to change the seal, or can I just loosen the adjuster and pry the shaft out? Just wondering if anyone has tried to do it this way?
It is such a minor issue, if I have to take the cover off I probably won't bother until I have another major issue with the motor out.
Thanks a lot!
OIL SEAL (10X16X4.5)
91259-VM0-000
http://www.westernhonda.com/fiche_s...ry=MOTORCYCLES&make=HONDA&year=1980&fveh=3431
Other side of the pond
The clutch cover has to come off Brian, so you can get the clutch lever out. You can do all that without pulling the engine back out.
dont for get to get a paper gasket too .
OK, Thanks!
