I am back to restoring (well, have running, at least) my 79 wing. I had taken the brakes apart a few years ago to rebuild the calipers and did so but never reassembled the whole kit. so, now, it sits there and I can't find the banjo bolts to the brake lines. can someone post a photo or a link to one? part numbers may also be great, since I'll likely have to order me some.
thanks
Here you go..note the ones above seem too short but it could just be the picture is
stretched???
http://www.hdlparts.com/fiche_section_detail.asp
25 BOLT, OIL 90145-300-010
(replaces 90145-300-000) 006 $5.01
25 BOLT, OIL 90145-300-010 006 $5.01
Hi, RB. is that a brake line bolt? the one that fits into the caliper the same as the one for the fitting above at the bars?
i have lost mine so I'm not sure what they look like.
also, if anyone has some of these parts, I"m willing to buy off of you.
I THINK all the banjos in the system are the same size but not sure..check the parts diagram..they give sizes..hell if you have one from the caliper end remove and see???
