Can you down size the tire on a 1500
689 Views 5 Replies 4 Participants Last post by  Ghost Rider 2
I am thinking of dropping a size on the front of my 1500 Wanting to use a 120/70 ZR 18 Dunlop D205. Will this cause any problem because of size? I am already running radial tires but the front is cupping bad. Have a new Dunlop here to go on my Kawasaki Concours. Thinking of installing it.
You will increase your stopping distance.
Project on hold. Found a jknot on the rear tire. New swet with about 7,000 miles on them. Front looks like it is trying to cup some. Felt a vibration on way homwe. Just figured it was the front because I could feel it in the bars heavy around 30 to 35. Checking everything over and found a bad spot on rear. Called where I bought them, they said warrantee, bring it back.
Good deal on the warranty!!
........and glad you found it after you got home and not at highway speeds!!!!
hi ghost rider the 1500 is not to be fitted with radial tyres
Not from the factory. But if you ever ride one that has a set you will want a set too.
