I presume we might see your plans on the forum?I have one similar to those, they work great. As mentioned, make sure you tie the bike off. Although I must admit, my home made lift works even better![]()
The places that sell "O" rings also usually sell kits to make your own. It' a cut and glue set-up.I've been using that CTC lift for about 3 years - one precaution, if the seal goes in the pump it is non replaceable, even from the company making the jack in CAL. I called & was told they could not sell rebuild kits for liability purposes. The "O" ring is not metric or imperial, it's a Chinese size not found in N America. I also tried a hydraulic shop & they said they call those jacks "disposable". :waving:
I picked one up last week, just for that purpose. I haven't had the chance to assemble it and try it out yet, as it's been too cold here for working in an unheated storage room. My buddy has had one for4-5 years and had to return the 1st one shortly after he got it, due to a leaking seal, but the replacement has been working just fine.I agree Hawker, I have no problems with the Jack itself, made the timing belt change easy. :waving:
