The starter will not engage & will not go into neutral. When the ignition is turned on the 'R' reverse light comes on but goes out when I hit the starter/reverse button, but the bike won't crank - the starter doesn't engage. The tranny won't go into neutral & the neutral light won't come on. the kill switch is in the correct 'run' position. Tried with kickstand up & kickstand down. I can feel the gears shift, but that's about all. I've engaged & disengaged the reverse several times - nothing. Help!
