Hi trike lady no there is no radio at all on the bike and junk yard ones are to much money for what you get so im looking for a way to put a car radio/CD player.
can you help.we,ll find a way.And thank you for the welcomeJeff
Hello and welcome to the forum,
Is the present radio not working? If not there's repair help available.
First, welcome.
No radio? Wow, what's in the space where the radio used to be?
There was a guy who built a rack to hold a single din radio in that hole, and I think he even tied it in to the handlebar switches. It didn't look easy. Try doing a search.
The CD player is a relic these days. Everything is going MP3, SD card, or USB. Usually all three.
Thanks for the welcome Dennis.there was nothing in the place where the radio use to be.
I did a search and there was a guy that use to make that set up for 95 bucks for a single din radio but I cant find his stuff I found his ebay sit but he hasent been on it for some time.I suppose ill try my hand at wood and fiber glass.Im much better with a wrench in my hand then a saw and fiber glass LOL.I don't know much about MP3 or SD cards or usb I know a little about MP3 but not a lot.Thanks for the feed back Dennis. if you hear any thing Please let me know Take care Dennis.Jeff.
Pretty much any radio today will have the SD, MP3 and USB ports and there's not much to learn. Just load your music on to a thumb drive and plug it into the USB port, the radio will let you control what to play.
When the crappy little Kenwood stereo on my beast bit the dust, ,I came up with a trick to install a 21st century car radio with Bluetooth (pairs to helmet), Aux-In (playlist from iPhone goes through radio speakers), USB port(accepts thumb-drive MP3 music with almost unlimited hours of listening) AND I can use the USB port to charge the iPhone so the battery never goes dead on long trips. The radio has a remote control so my passenger (mama) can change the channel, volume up & down, and with 18 presets she ALWAYS finds a good channel.
I used a "blank-off" panel that bolts up to the same "mounting holes" as the stereo on other GL1500's, I cut a slot for the face of the radio and mounted the "body" of the radio on a metal plate under the centershelter. IT IS THE PERFECT SOLUTION TO THE PROBLEM!!!!
This is what I did and how it turned out,
I have blank-off panels available (black only). Some of the guys use a Marine quality radio and it works flawlessly. You have 3 inches of clearance at the front(closest to dash) and 3 1/2 inches at the part where the panel angles downward to match/meet the gas cap door.
The panels are a modification of the original and is reinforced to additional strength to handle the newer radio.
Check out some pics of the Unobtainium 2.1 panel,
I've sold many of these world-wide and charge the members here the SAME $$ amount that the "vendor" charges me, , I make $0 profit to members. PM me if interested.
More info at https://www.goldwingfacts.com/threads/83155-mw5-xxx-unobtainium-2-1-stereo-blank-off-panel-for-gl1500s.667013/post-5836373
