Had the air cleaner and housing out to see carbs, couldn't find where to adjust the carbs. Need help out there
Not sure what you want to adjust but ... Mixture is at the front of the carbs (go in between the rads) sync is from the right side. Hope that helps.
That's what I was looking for Jim. Thanks for the info. I looked all around the sides andrear but to my surprise, no see-um. Have a 1995SE, with an up and down idle. Thought I would give it a go at adjusting them. Thank's again. Terry
Try rocking the idle screw by the gas cap back and forth several times. Sounds strange, but there is an old thread here where several people found this to stop their wandering idle speed.
