1 - 19 of 19 Posts
I got a pair of vacuum gages from HF and was reading the instructions posted here on balancing the carbs and the only thing I am having a problem with is I do not have an adapter for the vacuum ports on the intake, everything I have or came with the gages is way to big? I cannot find a topic on the adapters so I thought I would ask and hopefully someone else had the same problem and found an answer.
thanks for any help
i made some from 3/16 brake line, ran a die over it screwed a nut on and an "o" ring, i sent some to someone here if you want a set pm me your name and address
1985 GL1200 Limited Edition
Try Wal Mart's aquarium supplies....
While on this subject I have the Forums gauges on the way here. Has anyone used those. I was told they don't have a way to adjust the gauge bouncing out.
I used nylon bolts. They're easier to drill. I believe I used 8-32 screws and nuts. Easier to find. The size is close enough to the 5MM thread in the manifolds and the nylon is soft enough that it won't damage the threads in the aluminum. An O ring and a nut seals them well at the manifold. If you can, use bolts with an un-threaded section under the head. It will be easier to seal the hose to the bolt. Of course, cut the head off.
Lyle
I believe I will by the Carb tune..sounds like the best one out there.
Why cant you just get some copper tubing and Thread it?
Sure you can make them,i thought about it but as mentioned before they are fairly inexpensive to buy. I would worry about using plastic, it gets pretty hot down there. I was lucky enough to have access to a set of Morgans and they where the best. A good syn. will amaze you of how much better she will run.
Jim
I bought guages but returned them when bike and dennis refered me to motion pro,i bought a set of adapters,then took a closer look at ther site and went with ther fluid gauges I'm glad i did.I bought the adapters befor returning the hf guages.
Yep. Dennis is usually correct,he has more miles than a few of us put together. Made my own gauges and removed and cleaned my rake after a so called (mechanic) i paid $500 to do it screwed them up. But the final sync.with the Morgans really paid off.
Jim
The Borrowed Morgans:claps::claps::claps::claps:
Discussion Starter #14
I took your advice since I already had the break lines and copper tubing available so I cut 2 sections off the brake line, threaded it, added the nut and "O" ring and then I inserted the 3/16 steel line into a short section of 1/4 copper tubing and soldered it. I needed to increase the size of the 3/16 since the vacuum hose inside diameter was about 1/4 inch, after that everything worked great........now I have another problem, first I am only using 2 gages and hooked up both to the left side first .......my problem is both gages are fluctuating rapidly and will not stop, anything I do just makes the engine run worse then before?
if you ever got a chance to see the morgan carbtune in use and the simplicity in action you wouldn't even think of using anything else
1987 GL1200 Interstate
IC, there are some little gizmos you need to put in the tubes to stop the needles from bouncing. You get them at aquaruium supply stores.
You shouldn't even try to sync the carbs until you get the tool right.
Yep- Use small aquarium air valves as restrictors in the lines to reduce the bouncing.
Somebody told you wrong. As the Former Tool Master for the forum I can tell you right now the forum gauges do have in line valves to limit the needle bounce of the gauges.
For anyone who needs to see how to sync the GL1200 carburettors, here is a video:
1 - 19 of 19 Posts
