Hi all,
Ive read somewhere that carbs need balancing every 5000mls what I cant understand is why do carbs go out of balance my exsperience with carbs is with cars normally its a mechanical method of setting the throttle openings together so that the pistons rise together hence the mixture screw is then brought into play to alter the mixture not the vacuum.I`m thinking of buying a set of gauges but want to make sure of the events in setting this balancing topic is woth the exspence.
cheers to all.
cheers to all.
