Carb-hole info from smart 84-87 guys.
565 Views 3 Replies 4 Participants Last post by  Bagmaster
6
I have 6 pictures of 84 carb:
D diaphragm (top),
F float (bottom),
I intake,
O output,
B bracket side,
N no bracket side.
Please write when you check passages, where do you blow, where do you check.
It would be easier probably if write like:
D1 > B2, N3 etc.
thanks.
This info would be very useful for every 84-87 rider.
You can see if you look for the raised areas i.e in pic F below #6, these are passages. Some go straight through to an exit hole while others may go somewhere indirectly and have a peened in ball plugging the hole where the passage was drilled i.e. below #4 in pic O. Follow the passages to see where they go so you know if air or carb spray is getting where it needs to go.
Since you already have them apart, why don't you boil them? That's what the experts say to do.
Try blowing water through them using a water pic. It will give you a good indication of where they go or if they may still be plugged with gunk.
