Carb issues solved
738 Views 9 Replies 8 Participants Last post by  steve worth
I have this gl1200 that was resureected early this year after sitting outside for 3 years. I must have overlooked the carbs when I first cleaned them. I also think the eafoam doses loosened lots of vuilt up crud that ended up filtering in the carb.
I decided to pull the carbs last weekend and have a thourough cleaning . If this would have failed I would have opted for a full rebuld,
Cleaned all ports and blocked jets, se t the floats, replaced all vacuum and fuel lines , reset the pilots to factory setting and synched the carbs.
Thanks to this wonderfull site for the years of knowledge I have gained. The operation was a full success.
I cant believe the dramatic change. Just a touch of the starter button and shes purring, no more eratic idle. Due to the quick throttle response I no longer have to fear comming into slow turns.
One thing I have to get used to is sghifting again. I taught myself shifting with the rpms a bit high. Now the rpms go to idel immediatly after releasing the throttle. So every shift winds me down before surging back up to road speed.
Thanks all.
Ain't this place grand?
:clapper: on your success.
I just redid my carbs yesterday. I was trying to adjust the idle mixture screws and found they were way out.
After removing and cleaning the carbs, what a difference! I guess I really got used to losing a little here and there for a while (2 years since I did it last). I have to be careful now, I really have to hang on! Weeeeeeee!
i was debating pulling mine tomorrow and cleaning them as i do not know when the po last did. now you have convinced me.. tomorrow it is. clean the carbs, and if napa has them, change timing belts. then i will finally have all of the unknowns covered..
this site is awesome!
with all of this garage work i'm going to have to get me an A/C for the garage! :action:
Barry
One of the good things about the 4 cylinders is the carbs are easy to remove compared to those on the gl1500.
Idle jets are smallest ones and they are always clogged.
remember that b string metall guitar string isthe perfect size for those small jets.
Hey Muaymendez1,
You mean I can finally use that "B" string on my BASS for something..:cheeky1:
not the bass. My wife said the same thing. " You are finnaly using that guitar eh???
muaymendez1
Well done on the carbs and keep smiling....Steve
