I have a very bad leak in one of my carbs when it is running. could it be a float stuck or is there any thing else that would pump gas? I also had the bike laying down. :sadguy:
You had the bike running laying down????:readit:
Yes it could be stuck floats, is it coming out the overflow tube under the carb?
It could also be a leaking bowl gasket.
All depends where it is leaking.
Need more precise location/info:waving:.
floats stuck
my kick stand is broke so I have to lay it down when I get off.
Carry a block of wood with you and place it under the guard on the side.
I remember guys on Triumphs in the 70's doing that. No side stand so they wound just lean it against a wall or lay in down for a nappy.:shock:
