2 turns is twice around the clock 24 hrs
Wilf
Wilf
I don't know if your device is the same type as mine, but it does have the same functions. Check up here: http://www.goldwingfacts.com/forums/forum1/80256.htmlI need to do an idle drop. I've got a dwell/tach/volt device. How do I hook it up on my 12 to do the idle drop? I'm pretty sure one lead clamps to no. 1 plug wire but where do I connect the other lead?
If I turn the pilot screws in does that make it leaner?In my opinion it should require choke to start and run cold otherwise it is too rich when warm to be efficient. Turning the mixture screws in may help but usually it's the float level too high that causes rich running if the jets are original size.
