1 - 2 of 2 Posts
I used 2 quart jars with good seals on top to build this sync tool. The larger jars react slower because of more volume of jars. Used water and food color works great. Do not push on carb adjustment screws when you turn to adjust. Causes the carb be in sync then out when you remove the screwdriver.Balance water level across jars sit on level surface. It's simple to use and works with a little practice of amount to turn screws to balance. It's cheap give it a try. http://209.85.129.132/search?q=cache:1Cz5BkoSowMJ:faq.ninja250.org/index.php/Is_there_a_carb_sync_tool%253F+ninja+250+carb+synchronizer&cd=2&hl=en&ct=clnk&gl=us&lr=lang_en
1 - 2 of 2 Posts
