WENT TO SYNC THE CARBS TODAY. I HAVE A SET OF 4 GAUGES THAT I GOT WITH THE PURCHASE OF MY FIRST GL 1100 NEVER USED THEM NEW IN BOX. THE CARBS WERE ALMOST PERFECT. #4 WAS A LITTLE SLOW ON THE REV. MY QUESTION IS I HAVE ABOUT 5 INCH #S OF VACUUM, WHAT SHOULD THE READING BE? THIS CARB SYNCHRONIZER SET HAS THE 5 IN THE RED (LATE VALVE TIMING OR LEAK AT INTAKE). I RUN THE TEST WITH THE RPM'S AT 1000. THE GAUGE HAS NORMAL AT 18-22. JUST WANT TO SEE WHERE TO GO ONHERE, WHAT IS CAUSING THE LOW READING (OR WHAT SHOULD IT READ). THANX IN ADVANCE
81 GL1100I, 42K ROUGH IDLE, SOME SURGE ON DEC. WHEN UP SHIFTING
