1 - 9 of 9 Posts
Lost on this *****
I plan to synch the carbs on my '97 aspy and I purchased the TecMate CarbMate Carburetor Tester, but after reading the tutorial on here I see I need the adaptors. My question is what is the thread size, (5m or 6m).
I've never done this, so I'm a bit confused and not sure what I am exactly looking for.
My 1200 used 4mm. Not sure about the 1500.
Piled Higher and Deeper
As far as I know all wings are 5mm.. (guarenteed accurate for GL1100 and GL1500 since i have both..)
Like Sandie says, they are 5 mm. Brass ones are best if you can find them, the plastic ones tend to not last too long. A few times and the threads tend to wear and get loose.
Kit
I got the Motion Pro/ Sync Pro. Best $100 I ever spent. It came with all the adapters, restrictors, and hose. If you can take your Tec Mate back, not that I've seen or used one before, I would take it back if you're not able to use it right out of the box. You should'nt have to hunt for more stuff to utilize someones product.
Wichita Scorpion wrote:
5mm
CheapestI have found and fast shipping.
California Sport Touring
Yea, those are the good ones made of brass. Motion Pro makes a set also that come with rubber caps in case you want to leave them in all the time.
Lost on this *****
Thanks guys,,,,,,, I have the adaptors ordered.
1 - 9 of 9 Posts
