I have been chasing an issue with my new to me 1100.
"All it needs is a carb rebuild" got me sucked in and I have been on the trail of the problem for a while.
To make a long story short....
I found 2 idle jets were plugged through the main hole that goes through from one end to the other. the little holes were fine.
I am hopin opening those up fixes at least part or the whole problem.
I was running cold on 2/4 cyl. and hot or normal on 1/3. I am thinkin hot.
I am getting spark to all 4, new plugs, fuel to all bowls (did the gravity fill test) levels good.
I am going to change out the plug wires and caps just for good measure....and to eliminate a potential cause of low fire/spark.
all valve/sync good (though now when I re install I will check)
The only other thing I am going to do is check / give another polish to the cv sliders and bolt them back on and hope for the best.
Anything else I should do while I have them out? Do you think I fixed the problem?
thanks
thanks
