Hi There,
Can you advise on this subject. My GL1500 1989 is going for a major service and some paint jobs, and I am off to Laguna Seca for 2 weeks Moto GP, but thats another story.
My question is, should I have the carbs re balanced, as to my knowledge the bike has never had this done.
I am sure I read on this site that it should be done every 20,000 miles, but am not sure.
The bike is running fine. Should I just leave well alone
Dave
Mallorca
SPAIN
while all I have is a '78 and '86, I have never re-balanced the carbs on either one. The only time that I would think it would be needed is when the carbs are rebuilt, or the bike is not running correct.
When I owned a 1500, I checked the carb balance annually but never needed to adjust them. If it runs evenly on tickover, picks up cleanly and gives good fuel economy I'd go by the old saying;
"If it ain't broke, don't fix it".
jukeboxjury123 wrote:
Hi There,
Dave, that is a tough decision. If it runs great now there is always the chance it could run worse after a carb balance either because it is set just where it needs to be now or the guy doing the work doesn't get it back as good as it is now.
If I were doing it I would balance it myself & if close just leave it where it is, or if it needs balancing would mark all the things adjusted so I could put it back if it runs worse after the adjustment.
Twisty
Dave, it's not a big job to get the carbs balanced, just the lower fairing panels have to be pulled. I get mine done once a year (aboput every 8000 miles), if I leave it too long the bike gets a terrible flat spot and that's how I know the carbs need doing.
I keep reading about balancing the carbs. Is this fairly easy to do and how do you do it? I would like to look into this for my 84 GL1200 and see if it helps with my problems.
