copied from another forum.
Rusty Probie
Cycle Innovations manifold and Holley Carb
Post #3 by
highiron » Sat Sep 02, 2006 4:02 pm
The Holley Carb is a Model 1940, called the Economizer when it was reintroduced as a new replacement carb. It was available for many years and with slightly different linkages fit many Ford and Dodge cars and trucks. It was standard issue on the early Ford Mustangs with the 200 CID six. These carbs are in demand because of the Mustang application. Holley modified the linkage for Cycle Innovations, and today Holley apparently doesn't have any knowledge of the modifications or stamped numbers on these particular carbs. I am interested in possibly recasting this manifold. Does anyone know if it was patented, the patent number and what happened to the Cycle Innovations company? I am looking for a series of good photos of one, inside and out to see what the difficulty would be in making a pattern.
His carb info is correct'
I had one of these conversions, was the best thing I ever did to my '80 1100.
the carbs were special made for cycle innovations, almost identical to 1940 except for the cable spool and a triple stacked boost venturi, The overhaul kit for the 200cid mustang carb will work, as all the gaskets are the same.
I changed from the 4 carb set up because I was tired of cleaning and balancing them, Never had to touch it after that.
I had better bottom end torque, and picked up 2 MPG. Most likely because all cylinders were in agreement.
Cycle innovations went out of business in the 90's.
