As I'm fixing just a few small problems on my 1500, The next one is the CB. I had a feeling that it really wasn't working so good when I went by a truck stop at night& didn't hear hardly any chatter. I picked up an SWR meter & put it in line under the seat where there is a screw on type connector. I keyed the mic to set the calibration & the needle didn't move (that's not a good sign).
So today, I dug out an old CB radio & connected it to the antenna with the meter in line. I powered the radio up, keyed the mic & calibrated the needle & flipped the ref switch & it read half way between 3 & the end of the scale in the RED zone. Remembering my CB days in the late '70's, this is not good either. I tried adjusting the top antenna rod &it made little to no difference in the SWR. I checked the front coax cable (from the radio to the screw connector) to fine that there isa dead short. I unplugged the coax from the back of the onboard radio & put an Ohms meter on the center pin & the outer shield & it read .2 Ohms.
So I have two (possible three) problems. 1: I need to find a replacement coax, I looked at an a Honda dealers online page to fine the cable (while shown) does not have a part number. 2:I need to find a good antenna. I could put on the antenna off of the semi I used to drive , but that is a monster.Possible third problem is the power amp in the radio might be blown & need to be fixed.
So where do I find coax? Is there a good aftermarket antenna?:?
